99 Yamaha Beartracker Carb. Problem
Old Mar 27, 2006 | 07:30 PM
BSW's Avatar
BSW
Default 99 Yamaha Beartracker Carb. Problem
On the beartracker carb, There is a nipple sticking out the bottom that is to drain the carb if you open the drain screw.
When the drain screw is closed, nothing comes out, but when I put the fuel shut-off to the on position, fuel starts coming out the drain nipple.
HELP PLEASE!!!
Old Mar 27, 2006 | 09:40 PM
recon99's Avatar
I can think of 2 possibilities here. The one that is most likely is a stuck float, this will hold the valve open, and overflow the bowl (drain nipple is also the overflow nipple)
It's also possible that a seal went bad on the drain screw, but I never heard of that happening before. Start by removing the carb, taking the float bowl off, and making sure the floats are moving freely.
Old Mar 27, 2006 | 11:41 PM
BSW's Avatar
BSW
Thanks for the help! I'll check the floats.
Sjrpp
May 2, 2023 03:59 PM
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
ranvette
Jul 4, 2015 06:13 PM
