03" Grizzly - Overheat light on
Old Apr 5, 2006 | 12:41 PM
couvgrizz's Avatar
Default 03" Grizzly - Overheat light on
I just bought a 2003 Grizzly with only 220 miles on it. I just picked it up Sunday night and have only ridden it a couple of times (the day I looked at it for about five minutes and the day I picked it up).
Last night I had the key in the on position as I was working on the winch (I pulled it all the way out and then back in to tighten it). While I was doing so I noticed the overheat light was on. So I started it and ran it for a couple of minutes and the light came back on.
I am hoping someone may have had a similar problem and knows the different things I need to check.
Thank you in advance for your help!
Old Apr 5, 2006 | 01:41 PM
CBF2's Avatar
Does it have vents built into the black covers directly above the engine or are they solid? There is a heat kit available from Yamaha for 02s & 03s that included these plus other parts to try to cool them down. I have noticed a Grizz get very hot when standing still winching but the engine was running.
Old Apr 5, 2006 | 01:51 PM
hondabuster's Avatar
Check the coolant level, and make sure the radiator, isnt dirty or plugged.
Old Apr 11, 2006 | 12:37 PM
wolf23093's Avatar
Check the temp switch on top of the motor make you have not lost your ground to it. the connection between the switch and the harness gets corroded. its a short piece of wire 6' check both ends.
Steeldon
Sep 9, 2015 09:38 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
