Can you pull start your Griz???
Old Apr 11, 2006 | 02:28 AM
Backinthesaddleagain's Avatar
Default Can you pull start your Griz???
I have three buddies with Grizzlies.......none of them can be pull started.
Can you pull start your Grizzly?
Old Apr 11, 2006 | 05:41 AM
Hebs's Avatar
yes...
Old Apr 11, 2006 | 08:48 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Don't Griz's come with a back-up recoil on them? If not I'm sure they could add one.
Old Apr 11, 2006 | 09:51 AM
I know that it has a pull starter.........my question is are you able to pull start it???
My three buddies can not pull start their Grizzlies because of the compression and you nearly rip your arm off trying.
What are other Grizzly owners experience?
Old Apr 11, 2006 | 12:20 PM
Hebs's Avatar
Yes, I am able to pull start my grizzly. I usually pull the ripcord out a bit, stop and then pull the rest of the way to relieve some of the compression...
If your grizzly has a hard time turning over with the electric start, then it obviously makes it much more difficult to pull start it...
If it has a hard time turning over... check all of the basics... and then check the valves... they were a lil tight on my `02 griz... and it was making it hard to start in the cold...
Old Apr 11, 2006 | 12:22 PM
squeege's Avatar
My kodiak 450 aint easy....gotta put some a$$ into it
Old Apr 11, 2006 | 08:27 PM
bassmasterrap's Avatar
yeah there is a method of pulling it. Like Hebs said pull it out once a little bit. It will stop about 6 inches out. The let it back in then pull it hard. It always works. Its still not easy thought. If you think a grizzlys hard to pull start try to pull start a honda rincon.
Old Apr 12, 2006 | 08:29 PM
Anymore Griz owners out there???......BTW, I'm asking about the 660 Griz.
Old Apr 18, 2006 | 12:05 PM
ChevyThunder82's Avatar
Have an '06 and no problems starting it with the pull start.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
