Help with my Warrior's starting system..
Old Apr 19, 2006 | 02:17 AM
cotton's Avatar
Default Help with my Warrior's starting system..
i have a 1998 warrior, that i need to badly sell, this problem occured while it was pretty much sitting in the garage. i dont ride it anymore, just once in a rare while, it wont start unless i push start it! there is no spark when i crank it? i put a new plug in it, i called the dealer and was told that it could be the stator, i pulled it off the other day and checked it all out... not sure how to check it... it charges tho, the lights work fine. i could really use some help??
>also my clutch is slipping, just changed the oil. it only seems to slip in 4th gear and up, if u have the throttle at about 3/4 then hold it wide open u can hear it and feel it slipping till it catches up with itself... is there adjustment on these?
Old Apr 21, 2006 | 03:38 AM
cotton's Avatar
back to the top! anyone??
Old Apr 21, 2006 | 04:09 AM
2FAST4U69's Avatar
I would say stator or cdi/ignition
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
