WARRIOR REAR CALIPER
Old Apr 20, 2006 | 08:06 PM
STORMIN's Avatar
Default WARRIOR REAR CALIPER
I have a 88 warrior with a messed up rear caliper what other caliper will work on it? The Banshee and YZF 450 rear caliper look the same what do you guys think.
Old Apr 20, 2006 | 08:13 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
????? Why not just get another warrior caliper?
Old Apr 20, 2006 | 08:24 PM
STORMIN's Avatar
Ido want to get another but they are big bucks to buy new and hard to find used. I have seen some on E-BAY for cheap but not all are WARRIOR calipers.
Old Apr 20, 2006 | 08:46 PM
Monkey Rider
Afro-Engineer
I would guess the banshee and raptor are the same? not totally positive though. 220 bones is some coin thats for sure.
Monkey Rider
Afro-Engineer
Old Apr 20, 2006 | 11:38 PM
recon99's Avatar
The banshee and raptor 350 are definitely the same, I think raptor 660 too. These are very common calipers, my cousin's 86 zuki quadracer even has the exact same thing. Try using an online yamaha parts finder and compare the part numbers to different models that you think may fit.
Old Apr 21, 2006 | 11:05 PM
jrscycle's Avatar
whats wrong with it?, they can usually be repaired.
Old Apr 21, 2006 | 11:35 PM
STORMIN's Avatar
The bleeder screw stripped out. I tried oversizing it but the tapered end wouldn't seal
Old Apr 21, 2006 | 11:51 PM
Sparky8370's Avatar
I wonder if you can buy a bigger bleeder, say for a truck caliper or wheel cylinder, and drill and tap it to a bigger size. Probably a npt type thread, so you'd have to get the right tap so that it would have the taper you're refering to. Just make sure that you do not run it in too far, as you'd lose the taper. And make sure you flush out good afterwards.
Oh and my brother put a warrior caliper on his quadracer and it bolted up fine. Only difference was the way the ebrake connected. Should be the same on many models.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
