New 450 Wolverine?
Old Apr 25, 2006 | 09:08 AM
BillyMack's Avatar
Default New 450 Wolverine?
Sounds like a great bike guys, but my buddy just picked up his brand new Camo Vinny w/ AWESOME wheels and tires ( ITP ). Preciate the replies though!!!!
Old Apr 25, 2006 | 01:46 PM
mcain2's Avatar
Originally posted by: nypaul06wolverine
I have about 200 miles on my 450 wolverine and I think it is all around the best quad out there for riding in the woods. Its not the type of quad that your gonna use for hunting or plowing your driveway. Its also not the type of quad that you can race on a motocross track. But, as far as riding in the woods over all kinds of terrain you can't get a better or faster quad. This quad walks all over utility quads in the woods because it is much lighter and sportier. And as far as going up against sport quads its awesome because it will go through all types of stuff that sport quads can't make it through like deep water, mud, big rocks, and steep hills. The four wheel drive works great. In my opinion there is nothing else like it out there except for the polaris but everybody knows that polaris doesn't compare to yamaha.
I agree with you nypaul. I could not be happier.
Old May 11, 2006 | 06:27 PM
highflyer91's Avatar
I have a 2006 wolverine 450 /white/4 months
You can do all you want to the engine or clutch, but you will only pick up MAYBE 2 mph. increase in top speed.
Take your wolvy down a long strait hill and open it up. your top speed here may be 55 mph. the final gearing of the drive train sets the top speed of any auto tranny, no clutch kit will cange this. The only way to change top speed is to install larger tires, gearbox ratio, axle ratio. And if you can find the gears in aftermarket LET ME KNOW !!!!
A clutch kit will cange the amount of time taken to reach top speed, but thats it.....
I will never install larger tire, just to gain top speed at the expense of bottem end....
My Suggestion!!! If you want a woods warior leave the 23" tires
Yamaha GYTR Header Muffler
Install K&N FIlter
Place Small Headlamp on handlebars
YAMAHA handgaurds are a must !!!!
Intall a hitch on rear
Jet Kit UP 2 SIZES the factory runs lean!!!!!
NO CLUTCH KIT !!!!
Premium Fuel Only
ENJOY
Old May 11, 2006 | 08:39 PM
06wolverine's Avatar
Ru u sure about jetting up 2 sizes with the gtyr muffler & k&n. I put both on my 06 wolverine, took it to the shop and said it needed a bigger main jet (i don't do carbs.) the next day they called and said it was fine doesn't need to be rejetted, also had them look at the valves and they were ok. I haven't had a chance to ride it since I put the stuff on it due to a disagreement between my table saw and my thumb.Maybe a couple more weeks and i can take it out and see if it is lean or not.
Why run the premium fuel?
Why don't get the clutch kit?
This is my 1st quad so I am new to all the mods and stuff.
Old May 11, 2006 | 11:35 PM
  #15
HappywithVForce's Avatar
I would like to see if a clutch kit can give the bike a snappier throttle. I dont care about top speed, but I need more of a power HIT when I hit the gas.
Old May 13, 2006 | 12:57 AM
  #16
LW's Avatar
LW
How's the Wolverine's suspension going through rock gardens, whoops, and moderate jumps? Do you get bump steer going through rock gardens?
Old May 14, 2006 | 06:47 PM
  #17
whoops are not so good, moderate jumps are ok just don't go for big air it will bottom out the shocks every time, have not had it in the rocks yet.
Btw mine ran rich from the factory
Old May 15, 2006 | 12:49 AM
  #18
LW's Avatar
LW
I'm wondering if you replaced the suspension with performance suspension would it significantly perform better. My theory you would be getting some of the best parts: 4 wheel drive for mud and crawling and great suspension for the whoops & jumps. I don't think it's the weigh that's holding it back, because the Bombardier ds 650 must weigh about the same. Though I don't know, it could just be a design thing.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
