The TRUTH About Oil Injection
This is an article I read on line, and i just wanted to get some of the experts input. so I posted it here….
What you should know before you block off the oil injector
Nearly everyone complains about the oil injector (Autolube) that comes stock on every Yamaha Blaster. Some say it is unreliable, and will break. Others say that the 20:1 mix ratio puts too much oil into the motor. Many people block off the injector for this reason, there are many kits avaliable to do this.
As a Blaster owner for two years, an everyday reader of the Blaster Central BBS, I belive I have heard nearly every argument for and against the oil injector.
In the past few years I have heard of 3-4 people who say their injectors have gone bad and caused their motors to sieze. Most of the time they do not even consider that other factors could be involved. The just assume that the injector must have quit, every so-called expert says it isn't any good. Still, no one has ever proved that the injector was at fault.
Even IF it was, improper care usually causes failure. I have to wonder if the operator was carfull when he filled the tank up, or if he filled it while the quad was dirty and droped bits of mud into the tank.
I belive the Blaster's oil injection is 100% reliable. While I realize anything, and everything can fail, I do know that the injector system is no more likely to fail than any other engine part.
The fact is, my own 1998 Yamaha Blaster's oil injection system has held up to 5175 miles of use, without a single problem.
The first ATV ever to finish the 6000+ mile Paris to Dakar rally was a 1997 Yamaha Blaster. He ran oil injection, and the quad ran fine the entire time.
I sure hope that dispells the reliability myth.
Most people belive that the Blaster's 20:1 Gas[img]i/expressions/face-icon-small-blush.gif[/img]il ratio is too rich. They say the motor gets too much oil. I want my motor to get all the oil it can. The more oil If it costs my 1HP, then fine.
Wait a second, it won't cost me horspower!! I might actually lose power by running a leaner ratio. I know you don't belive it, that's why I have proof. Tests have been done on an lder RM125, and these are the results:
20:1 Gas[img]i/expressions/face-icon-small-blush.gif[/img]il ratio (same as a Blaster) gave 23.2HP 16:1 Gas[img]i/expressions/face-icon-small-blush.gif[/img]il ratio gave 23.6 HP 27:1 Gas[img]i/expressions/face-icon-small-blush.gif[/img]il ratio gave 21.4 HP
At the 27:1 ratio the piston "showed signs of scuffing bad enought to deter me from testing at 32:1."
If you think I made all of this up, take a look at page 169 of Two-Stroke Performance Tuning by A. Graham Bell. The book is avaliable on Amazon.com for a fair price.
Any other questions about the injection system. I have proved it to be both reliable, and that it does not cost power. Now I'll tell you why people say they remove it:
Looks, they say it looks bad.
Weight, it weighs a few pounds.
It doesn't look great, but it doesn't look terrible, at least not to me. On a tricked out quad, it might detract from the appearance a bit.
Hmmm... I guess it does weigh 2-3lbs, and full of oil, mabey 6-8. So that's a valid complaint.
There, now I have told you both sides of the story, make your own desicion. I just don't want people to spend their time and money taking off the injector before they hear the other side of the story.
Click the link if you'd like to flame me (or if you have intellegent comments): rockosmith@aol.com
Very, very well said duckdiaz. Exactly how I feel about oil injection.
The only thing I take exception to is 32 to 1 causing scuffing. I've run 40 to 50 to one in every two stroke I have ever owned and have never stuck a piston. I have a 20 year old chain saw that has seen nothing but 40 to 1 in it and it has 50+ cords on it. Still runs great.
Ask the Editor
12
Jul 21, 2015 06:57 AM
