Grizzly top speed loss
Old Apr 27, 2006 | 05:13 AM
Jakkals's Avatar
Default Grizzly top speed loss
I have a Grizzly 660, 300 hours, 10000 km(6200miles) 2005 mod with dyno jet and K&N filter on. Other wise it is stock standard.
On a level road it normally go 102 km/h but now it only get up to 92 km/h.
I have cleaned the carb and air filter, checked the valve clearence, changed oil and spark plug.
No improvement.
In low range it normally hit the rev limeter at 65 km/h and now it is 56km/h.
How do I know if the clutch, belt or pulley is ok?
Old Apr 27, 2006 | 06:23 AM
Starky's Avatar
I would say either your belt is worn or you have mud in your clutch. Both of those items will decrease your top speed.
Old Apr 28, 2006 | 07:11 AM
Jakkals's Avatar
I have opened the belt/clutch cover. The belt look fine and i can see no mud but when i put it in neutral and rev it a bit the variable pully push the belt out but only to about 10 mm (3/8) from the outside of the pully. Is this far enougth? Is the clutch on the front or the rear pulley?
Thanks for your help.
Old Apr 28, 2006 | 11:24 AM
zappa24's Avatar
I would replace the belt and regrease the primary clutch. With that many miles on it I really think it will help
Old Apr 28, 2006 | 09:04 PM
OGGYDOGGY's Avatar
I agree thats a lot of miles on one belt.
Old Apr 28, 2006 | 11:39 PM
IdahoVinnie's Avatar
Someone correct me if I am wrong, as most of my experience is with snowmobiles.
Both "pullies" are clutches. You have a primary clutch (mounted on the engine) and a secondary clutch (mounted on the transmission). At full engagement (high rpms), the belt should be fully to the outside of the primary clutch. If it isn't, you will have a lower top end speed. The cause can be either in the clutches or the belt. As they said above, in your case it sounds like a worn belt. As a belt wears, it gets narrower, and will not fully attain top speed.
Old Apr 29, 2006 | 03:33 AM
Jakkals's Avatar
Thanks for the advice. I will update you all.
Pehter
Oct 3, 2024 11:00 PM
cboler9
Sep 24, 2015 08:35 PM
Sw00p
Sep 24, 2015 02:50 PM
ReconBayou
Sep 23, 2015 02:41 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
