Warrior neutral problem...
Old Apr 27, 2006 | 01:37 PM
4wheel4food's Avatar
Default Warrior neutral problem...
I have a 2000 and a 2003 warrior..Both of them have the same "problem"(actually more of just an annoyance)...
After the bikes run for more than 5 minutes or so(nice and warmed up) it is very "tricky" to shift into neutral...
Seems like I spend a good minute or two searching for neutral...
Sometimes my 2000 won't until it cools off....Has anybody else seen this and what could be the causes?
Any help would be appreciated...Thanks[img]i/expressions/face-icon-small-blush.gif[/img]
Old Apr 27, 2006 | 07:55 PM
recon99's Avatar
It's from the clutch dragging, try a better quality oil.
Old Apr 27, 2006 | 08:11 PM
paintballbanshee's Avatar
I have the same thing with my 2001 warrior, Its so much easier to just tap it down from second gear to neutral.
Old Apr 28, 2006 | 12:27 PM
NLWarrior01's Avatar
had the problem with my old Warrior, but it was usually only after riding good and hard with a lot of spinning of the tires .. found the easiest way was to shut the quad off, click into neutral and you're there. Never a problem then.
Old Apr 29, 2006 | 11:00 AM
Budwiser's Avatar
same thing with me, all i have to do is tap it and it will go inton neutral
95wolv
Sep 27, 2024 12:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
