450 kodiak grease fittings
I have a /05 /450 kodiak & I just change the tires on it & i noticedthe grease fittings on the rear axle are facing in so you can't get a grease gun on the fittings unless you take the hubs off also on my 06 grizzly the grease fittings are fine they face out to the tire so you lust take the tire off & grease them can anyone tell me if this is right on the kodiak or did the hubs come from the dealer on the wrong sides
I went to my local autoparts store and bought angled zerks. I simple removed the straight zerks and replaced them with the angled zerks. Now I can easily grease my kodiak easily whenever I decide to. In a previous post I listed the actual size I replaced it with. It was metric but not sure what size.
thanks windmill I rode with a 06 kodiak this weekend & looked at his it was the same but the factory had allready put angled fitting in like you said you did
Replacing them is the only way to go. Just get some from your local auto parts store. It's a breeze to grease it now. You"ll also need a needle adapter to reach the front u-joint. The drive shaft has to be rotated into just the right postion to reach it.
