HELP BANSHEES HARD TO SHIFT
Old Nov 19, 2000 | 10:01 PM
spencer's Avatar
I have a 92 shee and it will not shift from 2nd to 3rd when Im racing or shooting a hill but its just find when Im riding around does anyone have an idea whats up with it I picked it up used and have had this problem since I got it.
Thanks
Spencer
Old Nov 20, 2000 | 10:53 AM
spencer's Avatar
Come on guys give me a hand I dont know who else to ask.
Thanks Spencer
Old Nov 20, 2000 | 11:04 AM
Zorro's Avatar
it's normal.
Get used to it, it will be a bit better (I frequently miss gears when "racing").
Something you can do is put some teflon whatever that makes manual gearboxes smoother. I really can't remember the name or whatsoever, but I'm sure it's teflon based.
Old Nov 20, 2000 | 12:06 PM
duneyfz's Avatar
When you're racing, make sure you are letting the lever all the way down when you up shift. I found that when I raced, I always had my boot under the lever, ready to grab the next gear and I wasn't allowing the level to go down all the way, so every time I shifted I got the same gear. If you don't let it down, it doesn't allow the lever to grab the next tooth on the shift star.
Old Nov 20, 2000 | 12:53 PM
xtreme165's Avatar
Spencer, All you have to do is take out your clutch basket and behind it there is a shift linkage with an adjuster turn the adjuster and your problem is solved! My buddy has a 00 banshee and he had the same problem its an easy fix if you know what your doing but honestly its not hard.
Old Nov 20, 2000 | 03:06 PM
Zorro's Avatar
Yeap. Duneyfz is right. It does happen to me when I don't think about it. Watch this.
bvolks
Sep 13, 2015 12:57 PM
essonlaker
Sep 10, 2015 01:12 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Elkaholic
Sep 6, 2015 02:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
