Dissapearing Transmission Oil?
Ive got a 2000 Blaster and my transmission oil seems to be disappearing, i dont believe it is leakin b/c there is no oil spot anywhere on the engine i can find and there are no oil spots on my garage floor, however, all the oil will disappear between 8 or 9 days of topping it off, my friend has a 2000 blaster and he has the same problem. anyone else experiencing this and does anyone have any ideas??
Are your plugs excessivly dirty? I would suspect a gasket between the tranny and crank has gone bad and it is sucking the oil in and burning it. I have a 2000 blaster and mine was leaking right by the front sprocket. There was a crack in the seal there and I thought it was just chain oil and dirt, it was actually my tranny oil.
Jeff Roper
02-01-2022 11:48 AM
2000, blaster, crankcase, disappearing, disappears, dissapering, loosing, losing, oil, sprocket, sucking, tran, tranny, trans, transmission, yamaha
