Kodiak Wheel Offsets
Old May 10, 2006 | 06:57 AM
Ruffbuff's Avatar
Default Kodiak Wheel Offsets
Can anyone explain wheel offsets to me?
I have 4 new wheel/tire combo's all 25x10x12. Which one's go on the rear? The deeper wheels or the shallow ones? When I say deep or shallow I am refering to the inside view of the wheel. It appears that whichever way I have them, either the front stick out further or the back sticks out further. Is one way more acceptabel then the other?
Old May 10, 2006 | 09:59 AM
squeege's Avatar
The offset is because of the independent rear suspention...that throws the rears out about 2" per side compared to the ones that don't have IRS
If you look at striaght axle quads.... many have a recessed wheel in the rear the IRS dont
Old May 10, 2006 | 03:30 PM
Ruffbuff's Avatar
So should my rear wheels stick out further then my fronts in this instance?
Old May 10, 2006 | 03:39 PM
squeege's Avatar
yes....mine does and sometimes hit trees that the front tires clear
Old May 10, 2006 | 06:23 PM
Ruffbuff's Avatar
In looking at your pictures, I noticed that your rear end is not as exposed. On mine, the disc brakes are more exposed as is the linkage on the IRS. Is thsi a problem? Would it be bad to have the wheels up front wider then the rear as race quads do? What would be the impact?
Old May 10, 2006 | 08:05 PM
JohnnyFentress's Avatar
Hey You need to just get all 4 "front" wheels. thats what i did with my kodiak.
Old May 10, 2006 | 10:11 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
I agree. I had an 01 Kodiak with the deeper offset. When I tried them on my 05 they stuck "way" out so I went and bought two more with the shallow offset like the front wheels. They still stick out but not nearly as much.
Buck
Old May 11, 2006 | 12:01 PM
Ruffbuff's Avatar
I'll give it a try.
Thanks.
meddy0388
Sep 9, 2015 06:41 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
