Duel exhaust
Old May 11, 2006 | 10:54 PM
Raptor396Ryder's Avatar
Default Duel exhaust
Does anybodymake duel exhaust for the raptor 350? I have seen them for a warrior. The only problem is that you can buy a s/o for a warrior and pit it on the raptor, but the head pipe is different. So the duels for the warrior wont fit the raptor. If they are made what are some web sites they can be bought.
Old May 12, 2006 | 12:30 AM
recon99's Avatar
Nobody makes duals for the warrior or the raptor 350. There's no room for the pipes because of the clearances around the frame, and all the electrical stuff under the left rear fender. There wouldn't be a performance gain anyways, it would just have a weird sound to it because of the turbulence caused by a y-pipe, and actually would probably lose power over a standard slip-on.
Old May 12, 2006 | 02:04 AM
They must have been custom made. But i saw them on a warrior. Both pipes were mounted on the same side.
Old May 12, 2006 | 05:01 PM
recon99's Avatar
I hope this isn't the dual exhaust you saw!
I never saw duals on a warrior, maybe you're thinking of the DMC Alien? That's a single silencer with 2 outlets.
Old May 12, 2006 | 06:48 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
maybe he's thinking of the DC with the dual outlet... also,, if you were to do this.. you may not have enough back pressure and the quad may run poorly..
Old May 13, 2006 | 10:11 AM
YFZRyderMace's Avatar
Yeah i seriously dought it would run very good. I figure just a regular slip-on or a full system pipe would give you more power. Becaue Dirt Wheels put LTE Duals on the YFZ 450 and they said they got better power gains out of a slip on. But it you had a split head pipe like on a Raptor, or Predator it would probably give you more power but not with the Y-style head pipe. Jamie mace
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
