warrior starter rebuild?
Old May 28, 2006 | 10:48 AM
slowneasy's Avatar
Default warrior starter rebuild?
hey anyone know if they sell a rebuild kit for warrior starters? my 2000 died tore it apart and cleaned her all up and worked for a day then died again would like rebuild kit if available its a denso starter, thanks
Old May 28, 2006 | 11:38 AM
recon99's Avatar
The local powersports shop rebuilt mine about 6 months ago. He charged $20 for a brush set, and $10 for the installation. So you can get new brushes if yours wore out, but where at i'm not so sure.
Old May 28, 2006 | 01:50 PM
TORK's Avatar
I'm hooked up with an outfit called N2 performance ATV parts. They have brushes, brushplate assemblies, or complete starter rebuild kits that include brushes, seals, and bearings. Do a search and find a dealer near you. They have complete starters for about half of what the OEM's want. If you can't find any dealer let me know and I will find closest one to you. TORK
Old May 29, 2006 | 10:08 AM
slowneasy's Avatar
thanks will look into that are the brushes usually what goes wrong with them? this one has two brushes cleaned them up but dont know if there worn out or not never seen good ones to compare it to. not a whole lot inside the starter, but when i cleaned her all up and put her back on it seemed like it was dragging worked five six times and died again.
Old May 29, 2006 | 12:19 PM
recon99's Avatar
sounds like the brushes are worn out to me
Old May 29, 2006 | 08:10 PM
TORK's Avatar
Normaly brushes are all you need. Clean up good and lube bushings. Should be fine, brushes get short or wear funny and stick.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
ghost civic
Jul 27, 2015 03:15 AM
