warrior motor noise
Old Jun 11, 2006 | 10:28 PM
tdragano's Avatar
Default warrior motor noise
You can quiet it down a little by going with the minimum on the valve adjustment spec.
Set the Intake valve for .0025 - .003
Set the Exhaust valve for .004 - .005 (this is slightly less than the OEM manual calls for, but this still leaves plenty of room for heat expansion. This is what Mickey @ Four Stroke Tech recommends).
Old Jun 12, 2006 | 09:51 AM
pixie's Avatar
I am going to try to tackle it myself now. I found a complete step by step procedure for it , looks simple enough. Thanks for all the help.
Old Jun 14, 2006 | 12:05 AM
pixie's Avatar
tackled the job myself and I have a victory thanks for all the help
Old Jun 14, 2006 | 08:17 AM
GlennJ's Avatar
Nice work! Wasn't too bad, was it?
Old Jun 16, 2006 | 09:58 AM
  #15
YFM4FAV's Avatar
For what it's worth, I have a 2006 350 air-cooled Bruin and it makes the same obnoxious ticking sound. I, too, thought it was abnormal and let a Yamaha technician listen to it - he didn't think there was a problem. Still, I was concerned about the valve adjustment. So, I checked the valves and they were only a couple of thousands off. I made the precise adjustments to both intake and exhaust and then changed the engine oil and filter. It's still loud. Bottom line is that it appears to be a normal sound for this engine.
My 2006 400 liquid-cooled Kodiak concerns me with the knocking type sound it makes, which in the end will also likely turn out to be a normal sound for that motor. Both machines have been making these sounds since the day I brought them home.
Vince
Old Jun 16, 2006 | 10:44 AM
  #16
Speedy2222's Avatar
Is A Power Sport Junkie!
those specs are way off... i wouldn't recommend using them just because the exhaust calls for .00630 ~.00787
Old Jun 16, 2006 | 10:09 PM
  #17
pixie's Avatar
I set the intake at 0.005 and the exhaust at 0.007 and I have no engine tick at all,it runs great. My timing is slightly advanced (less than a tooth) I think my cam chain is just stretched. That will probably be my next repair.
Old Jun 16, 2006 | 10:12 PM
  #18
Speedy2222's Avatar
congrats man...
akguy31
Aug 31, 2019 04:34 AM
bvolks
Sep 13, 2015 12:57 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
