Winch Install
Old Jun 9, 2006 | 11:35 PM
wildwest1011's Avatar
Default Winch Install
I just got my winch today, I have read through all the directions and all seems rather simple. I just have one question, I'm supposed to splice into a wire that goes to my ignition, I'm wondering the best way to do this. I know to use a electrical tester to make sure the wire is only 'hot' when the key is 'on.' But I dont know where I should splice in, close to the ignition? How should I do it? With wire nuts and electrical tape? Should I apply that dielectic grease on the connections? I guess it was more then one question, any help would be appreciated.
Old Jun 9, 2006 | 11:44 PM
silent101's Avatar
the driections should tell you were and how to splice them i know my friend wired his stright to the battry and has had no problems with it discharging the battry.
Old Jun 10, 2006 | 08:16 AM
The directions show where to put all the wires except the one that comes from the ignition. Wires will be hooked directly to the battery( + and -). But hooking a wire for the rocker arm control to a wire that is only live when the key is on will prevent the winch from draining the battery, or being powered when the key is 'off' is not shown, just a generic pic of ignition and the wire going towards it, I guess the best way to find out is go for it.
Old Jun 10, 2006 | 10:31 PM
silent101's Avatar
I GuESS good luck man
Old Jun 10, 2006 | 11:42 PM
agdexter's Avatar
I am pretty sure you can go to Radio Shack or other electronics store and get a splicing connector. You won't have to cut into the ignition wire. It looks like a tiny plasic "T" that you crimp around the wires and it makes the connections. I have seen the one you want, have not used it, but have used similar ones.
agdexter
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
