z400 rear shock installation on blaster!!! HELP
Old Jul 10, 2006 | 12:51 AM
lildeezul's Avatar
Default z400 rear shock installation on blaster!!! HELP
ok guys i just revieced my new shock, i drill the bottom mount, but i cant get this bearing out of my top mount.
i got to get it out, so i can buy a new one, so that my blaster bolt will fit.
how do i get it off
Old Jul 10, 2006 | 04:20 AM
fastestkidaround's Avatar
ok if u got the bottom drilled so it fits. then u got it started. ok u are NOT supposed to drill the top mount at all. wat u do is get a bolt the fits the top mount ON the shock nice and good. then make sure its long enuff to fit the mounts on the frame. u put bushings in the frame mount so the bolt is a bit smaller and does not bounce up and down very far u prob fell it kinda of hit and start to pull the back of the quad off the ground when u pick it up from the grab. and u put some spacers between the top mounts on the frame so it is straight and does not move side to side. hope u understand this. once u figure it out its really easy and striaght forward.
Old Jul 10, 2006 | 04:00 PM
ok. so u almost got it from what i hear. tight
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
Jul 15, 2015 02:07 AM
cSchwartz
Jul 9, 2015 02:40 PM
