What are the signs of it going bad?
Old Jul 26, 2006 | 02:06 AM
apny2nv's Avatar
Default What are the signs of it going bad?
Can someone describe how a one-way bearing sounds like before it starts failing. Sometimes on my 03 the starter will just spin & not turn the motor over. I would have to pause for a few seconds and then try again.
Old Jul 26, 2006 | 02:24 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
yep,,,that is the early sign
it will start spinning more and more,,,,and then just spin all the time
Old Jul 26, 2006 | 03:35 AM
Mr45auto's Avatar
Yank it before the spring fragments eat up the bearing surface under it and you'll have to replace that gear as well. DO NOT buy a replacement OEM oneway. The LA design is a huge improvement. Mine's been on my 686 since the first prototypes were out and it's holding up just fine. My replacement OEM oneway didnt last very long at all.
Old Jul 26, 2006 | 03:37 AM
Bing's Avatar
Super Quad Patrol
i second every bit of that info
check out raptortranny.com for a step by step tutorial on the subject
it took me about an hour to change mine with the proper tools
Old Jul 26, 2006 | 04:42 PM
Raptorracer2051's Avatar
I also agree, I just had to replace mine, But i just kept starting it even when it wouldnt work then i started pushing it off and I ate up the gear also, so I had to pay another 80 bucks to replace the gear. If i were you i would check out raptor tranny.com and get the LA one way.
Scooter's Shop
Oct 9, 2015 02:09 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
atvcollector
Sep 8, 2015 05:11 PM
blueandy88
Aug 31, 2015 12:42 PM
