660r raptor 2 gear tranny problems...
Old Jul 30, 2006 | 12:59 PM
bubbatheraptor's Avatar
Default 660r raptor 2 gear tranny problems...
i just bought an '01 yamaha raptor 660r, it runs great came with some mods. i am very satisfied for the price i paid. although it has the 2nd gear tranny problem many '01 '02 raptor owners complain about. what is the cheapest repair i can do? as of now i am just jumping from 1st to 3rd gear but i need the 2nd gear for trail riding, please help me.
thx, rod
Old Jul 30, 2006 | 07:42 PM
JLsparky7's Avatar
Buy a new 2nd gear for it and replace it. Its a lot of money if you take it to a stealership.
Old Jul 31, 2006 | 05:14 PM
MasterRaptor's Avatar
The difference between the 01 and 02 second gear is the number of cogs. 01 has 3, 02 and up has 4. You can run second, just don't jam first to second with out the cluth. Baby that shift and you should be OK.
If it does break, shut it down as soon as you can because that broken cog will take out the oil pump and fry the motor.
Old Aug 28, 2006 | 01:56 AM
MrOffroad's Avatar
There is one HUGE problem with running it the way it is.... When the shift dogs break off, they swim in your oil. If you're lucky, they'll just go the bottom of the pan and sit there. But if you're unlucky like I was last weekend at the dunes, the dogs start floating around and get jammed in gears, and lock everything up tight when you're out in the middle of Egypt. Cost me 900 bones to have the local Yamaha shop install '02 tranny.
Old Aug 28, 2006 | 12:27 PM
garyc660R's Avatar
If the broken dogs sit on the bottom of the carnkcase they will eventually chew up the oil pump gear on the clutch hub. You are asking for even worse problems if you continue to run the engine.
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
blpersinger
Jul 15, 2015 09:56 PM
black_thunder
Jul 9, 2015 05:58 PM
