MSR Raptor clutch
Old Nov 30, 2000 | 07:35 PM
UofABB's Avatar
The 2001 MSR catalog lists the MSR raptor (clutch lever and perch)for $37. I think thats what I payed for it from the dealer. The replacement levers are kind expensive at $22 and the perch alone is $21. It looks like there is only one model of Raptor with just different grip colors on the lever. There are also standard length and "shorty" levers but they both fit the same perch. Only Raptor levers will fit Raptor perches and vise versa. Hope this helps.
Adam Biossat
Old Dec 1, 2000 | 02:16 AM
RAPTORLIPS's Avatar
Hey Eric
I have to run Acerbis guards on my cross country dirt bike.What I've done in the past when the lever is to long is cut the end off till it doesn't rub or get caught.I've always been told that the molded ball shaped end of a lever was
for safety reasons in case of an accident a rider woudn't be seriously hurt by the lever.Don't know if this is true or not,but if so,the hand guard
will cover the end of the lever. It's easy to do,
just take a hack saw and cut it off where ever you desire then take a file and file smooth.
The question I have is, Is there enough clearance
for the guard at the clutch perch area?
Old Dec 1, 2000 | 09:40 AM
ERICsRAPTOR's Avatar
Raptorlips(he he),
It's kind of a tight fit but they work. You just got to move some switches(or move them back in case of wrecks like myself). The only problem is that ball. The brake lever is fine because it's angle is different than the clutch lever. I am going to try to do what you said as soon as I pick my raptor up tonight. Thanks for the advice.
Big Daddy D.
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
