Banshee idle screw fuel or air?
Old Aug 25, 2006 | 07:00 PM
JLsparky7's Avatar
Default Banshee idle screw fuel or air?
Just wondering if the banshee idle screw adjustment is a air or fuel screw?
Old Aug 25, 2006 | 09:27 PM
oldturtle's Avatar
All two strokes have idle air adjustment screws. All four strokes have idle fuel adjustment screws. So turning screw in on Banshee reduces air and will run richer. Turning screw in on my 400EX reduces fuel and will run leaner.
Old Aug 25, 2006 | 11:58 PM
JLsparky7's Avatar
alright, thank you much
Old Aug 26, 2006 | 12:07 AM
hondabuster's Avatar
Some 4 strokes use an air screw...the easiest way to know for sure, is if the screw is between the slide and the air filter...its an air screw. If its between the slide and the head...its a mixture screw.
Old Aug 28, 2006 | 10:18 PM
Six2notScaredofU's Avatar
On your Banshee when you removed your T.O.R.S did you add Idle screws? if you want too Vito's has a kit real cheap and it's easy to install.
Old Aug 28, 2006 | 11:20 PM
JLsparky7's Avatar
I dont think i need the kit, I took the whole TORS system off and took the switch out of the throttle and the thing idles great now. I havnt had a prob at all. Later on down the road when i have some spare cash ill get the kit but i have no need for it now. Thanks for the advice though.
slowgsxr97
Mar 18, 2022 03:40 AM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
