rejetting an '07 yfz450
Old Oct 22, 2006 | 12:50 PM
SoccStud9's Avatar
Default rejetting an '07 yfz450
how do u rejet an '07 yfz450? seems to back fire and just wanted to rejet it etc to see what that does. i have an open lid too and was told i should rejet for that also. thanx
Old Nov 5, 2006 | 11:09 PM
trapland's Avatar
Congrats on your new 07. I pick mine up in 2 days.
First, put your airbox lid BACK ON until you rejet or you could run so lean as to damage the engine.
Second, If its spitting/backfiring back through the carbs when you just start accelerating, you are lean on your idle/pilot circuit. You will know this if the popping gets better with the choke part way on. On your bike, turn the fuel screw out a little. With the lid on, carefully turn it in and COUNT THE TURNS. Then try turning it out to where it was plus 1/4-1/2 turn more at a time till you get smooth running off idle (when engine is warm).
To take the airbox lid off and/or add an exhaust, you MUST change jets in the carburator.
Old Nov 6, 2006 | 04:37 PM
tototo's Avatar
Ditto, what he said.
Old Nov 6, 2006 | 05:54 PM
bombrider04's Avatar
yep and I would check your airfilter to make sure it is clean contantly sinc having the lid off will allow more dirt in and I would recommend and exhaust and airfilter
Old Nov 6, 2006 | 07:16 PM
SoccStud9's Avatar
thanx for all the help guys!! i'm just gonna put the lid back on and rejet so it will atleast idle right. i have one more question. is it normal for me to gun my throttle and low rpm's and have my quad sputter and then take off a second later, seems to hesitate and then take right off. thats with the lid on or off too.
Old Nov 6, 2006 | 09:09 PM
trapland's Avatar
If its happening with the lid on, it sounds lean on the pilot jet. Refer to my tip on adjusting your fuel screw above.
Old Nov 7, 2006 | 11:25 AM
SoccStud9's Avatar
where is the fuel screw located?
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
Bm400ex
Jun 22, 2015 09:16 AM
