Raptor 700 Reverse gear problem
Old Oct 26, 2006 | 11:08 PM
Ohnitar's Avatar
Default Raptor 700 Reverse gear problem
Hi!
I think I have a problem with my new Raptor 700.
I bought a new Yfm700r 2007 in a Yamaha official dealer.
When I shift from first to reverse it goes like this;
1. Pull the clutch lever in,
2. Shift the transmission into first gear.
3. Turn to the right the reverse **** "Rev"
4. Shift (you feel the shift pedal apparently shift)
5. Let the clutch out
The reverse light goes on and I?m in first, or I listening the gearbox ?rrrrrrrr? and then I must try two or three times to get the moto into reverse gear. This happens about 90% the time I make a first to reverse gear shift. These are the only gears affected.
My dealer said ?these problem is normal in Yamaha gearbox in 20% the time, but in mine case this happens 90% the time.
Please help me.
Thank you
Old Oct 26, 2006 | 11:55 PM
orion8419's Avatar
you turning the **** all the way. i have never had a probelm with mine.
Old Oct 27, 2006 | 01:23 PM
RaptorGrandpa's Avatar
Try this, works for me.
2. Shift the transmission into NEUTRAL
3. Release clutch lever.
4. Pull clutch lever in.
5. Turn to the right the reverse **** "Rev"
6. Shift down as if you wanted 1st gear.
7. Let the clutch out
Old Oct 27, 2006 | 11:34 PM
GuelphsFinest's Avatar
i have the same problem (07 Raptor700R)
txkevin
Sep 21, 2015 02:02 PM
old quads
Aug 13, 2015 10:32 AM
kodiak450.
Jun 17, 2015 02:22 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
