Kodiak 450 is not a submarine-Need help now
Old Nov 8, 2006 | 02:19 PM
Sonicpilz's Avatar
Default Kodiak 450 is not a submarine-Need help now
OK guys...got my can of GUMOUT and gonna start taking it apart. Hope all goes well! I will post the results on here later.
Old Nov 8, 2006 | 06:37 PM
Sonicpilz's Avatar
Alright I'm spent. I took the carb off and looked at it. This thing was as clean as a preacher's sheets. No gum, no dirt, no crud...absolutely nothing! I cleaned it anyways and put it all back together and fired it up.......Exactly the same freakin thing. It runs good at idle.....if you turn the choke up it will idle up and skit.....at cruising speed it skips.....but at WOT it runs fine. Anything else you guys think it could be???
Old Nov 20, 2006 | 03:28 AM
rockrider's Avatar
I think you should take a look at your belt and clutches. If you rode it while the belt was wet it may have slipped and caused some damage. Alos there maybe crud in and on your clutches. I personally don't think you damaged your motor. Back in the day, we used to sink our old Suzuki Quadrunners all the time and then ride them home with milky white oil. Do an oil and filter change, clean the air filter and they'd run just fine.
Old Nov 27, 2006 | 09:09 PM
hondagrizzly's Avatar
remember exactly how it goes together. I strongly suggest buying a manuel book for the kodiak
Old Nov 27, 2006 | 11:44 PM
  #15
Hebs's Avatar
how does it run from 0 to 1/2 throttle... especially up hill or when pulling something? Does it feel like the belt is slipping? Also check vacuum hoses for clogs.
Old Dec 28, 2006 | 11:45 PM
  #16
shwagg's Avatar
take that engin apart and drain & clean well
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
