yfz450 trouble
Old Nov 12, 2006 | 04:09 PM
wille's Avatar
Default yfz450 trouble
My bike is missing and cutting out when it hits around 3/4 throttle im not sure if its lean or hitting the rev limiter or is this another problem? Doesnt matter how fast im going its just when I hit around that 3/4 throttle spot. Any ideas what the problem is? Its an 04.
Old Nov 12, 2006 | 05:50 PM
wille's Avatar
And i forgot to mention the engine is stock.
Old Nov 12, 2006 | 05:56 PM
enFORCER's Avatar
Maybe take a look at your air filter and see if it needs to be cleaned.
Check your spark plug as well.............[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 12, 2006 | 09:08 PM
nmoss8's Avatar
Mine was very slight before i put a slip on exhaust on, then it was really noticable. Try turning your idle rate up. It helped mine.
Old Nov 12, 2006 | 11:43 PM
Hebs's Avatar
I've had that problem on my 04 yfz as well... unfortunately... I don't remember what it was exactly... I can see it in my head... but it's fuzzy. It was a black plastic piece that had come loose, or wasn't screwed in right... Sorry I can't be of much help...
Old Dec 9, 2006 | 03:48 AM
breck's Avatar
I ride an 05 yfz450se and I had this problem, all I did was change the plug and it hasn't happened since. If you have already changed the plug and it is still stalling then you may be running to lean.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
