raptor nitrous
Old Nov 28, 2006 | 11:10 PM
fastblaster00's Avatar
Default raptor nitrous
Originally posted by: Nardski
http://www.nitrousexpress.com/power_sports/60111P.htm
is that a wet kit?
Old Nov 29, 2006 | 08:32 AM
Nardski's Avatar
yes
Old Nov 29, 2006 | 09:44 AM
EFI Powerbooster
Adjustable Dry Nitrous System For EFI Applications is that that kit is labeled as. and its 399.
if you want wet this is the one you need
The NX 1 Cylinder Piranha Nozzle system is designed for all 1 cylinder applications with out an existing fuel system for the nitrous kit. This system comes complete with new Lightning Solenoids, 2.5lb bottle, stainless steel bottle bracket, nitrous and fuel lines, relay and wiring harness, WOT activation switch and Jetting from 10-15-20-25hp.
Single-Cylinder Nitrous Systems
w/ fuel pump
its the 3rd one down. the one listed above it has nothing for your fuel system. this kit is 669.00. i wish they had one kit without the bottle casue id just use my 10lb bottle.
Old Nov 29, 2006 | 09:58 AM
Nardski's Avatar
Thanks a lot, do you know where i would mount the nozzle, I'm really bad with directions and i cant understand them very well
Old Nov 29, 2006 | 11:31 AM
  #15
well on a car u do it right b4 the throttle body, unless its direct port. is ur raptor 1 or 2 carb
Old Nov 29, 2006 | 12:20 PM
  #16
Nardski's Avatar
Its EFI
Old Nov 29, 2006 | 12:34 PM
  #17
Nardski's Avatar
Thats why I thought that the EFI power booster would be the right one, idk, any ideas guys?
Old Nov 29, 2006 | 12:40 PM
  #18
same ****, does it have one throttle body or 2, cause the 660s have 2 carbs and i didnt know if they have 2 throttle bodies on the 700
Old Nov 29, 2006 | 01:06 PM
  #19
Nardski's Avatar
Not sure, Im at college and i bearly ever get to ride or even see the damn thing, i'll check next time i go home, if anybody else knows then help me out here.
Old Nov 29, 2006 | 01:11 PM
  #20
i no how that is man. just got done with bein away at school. all ur gonna do is put the fogger facing the throttle body. its a lil y shaped piece.
fuel goes in here . . n2o goes in here
Y__ prays the 2 of them out like that towards the throttle plate
