blaster 240 carb
Old Dec 4, 2006 | 02:32 PM
400exnram's Avatar
Default blaster 240 carb
what carb can i use for a blaster 240 stroker motor. it runs with a stock one with stock jets well, but i have a banshee carb laying around with a intake the mounts to the blaster motor. will it work and be better then the stock carb?what outer kind of carb can i use? what about a airfilter set up?
Old Dec 4, 2006 | 07:07 PM
Boomer2's Avatar
I rhink the banshee and blasters have the same carb. I think alot of people are using 34mm Keihins from 250r's or 35mm OKoyo
Old Dec 4, 2006 | 11:42 PM
ShadyRascal's Avatar
You can fit a 30mm carb on the stock Blaster carb boots. They are available for around 170 bucks and will make a very big difference in your power, stock is a 26. The 30mm flat slides are available from Trenga or Valley Cycle.
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
joeyupton
Jul 14, 2015 11:51 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
