Kodiak Headlights
Old Dec 14, 2006 | 07:01 PM
captainskodiak's Avatar
Default Kodiak Headlights
I have tried them a little bit on a ride today, left them on a couple of hours of riding around the trails behind my house. There seem to be no problem with high heat or any electrical problems such as wiring or the plastic grill. They acutually seem cooler than the stock ones? As for the three wires, I used the black for the ground and the yellow lead for the power. The green wire I just cut and taped the end up, it is only energized if the switch is left in the low light position, so either shut them off or on the high beam setting. You could use either wire, they are exactly the same guage, just guessed on mine and it was the high beem wire. The performance of them is much better and doesn't seem to drain the battery or charging system in any way, such as dimming at low idle etc.
Old Dec 14, 2006 | 09:02 PM
gtnwood's Avatar
Again, very nice job.
Old Dec 15, 2006 | 09:54 PM
squeege's Avatar
I just might be the next in line for that mod......BIG thanks!
Old Dec 16, 2006 | 03:46 AM
Cool, I think you will like them. Hey squeege, are those 10" wide front on your Kodiak, or 12" wide? They look really wide, just wondering...Bruce
Old Dec 16, 2006 | 10:38 AM
  #15
squeege's Avatar
yeah.....10" on front and 12" on rear.....I wish I wouldn't of went quite so wide cause It steers hard....maybe power steering would be in order?
Old Dec 16, 2006 | 10:51 AM
  #16
Maybe we could figure out how to retrofit a Grizzly EPS on to the Kodiak? I wish. It took some gettin' used to with the wider front tires. Almost crashed a couple of times unil I got used to the wider track going thru fast, tight trails. Really llike the wider tires/rims for the stability, big improvement over stock. Where did you buy your overfenders? I saw some on Ebay for just over $100, might look at buying some in the future.
Old Dec 16, 2006 | 11:08 AM
  #17
squeege's Avatar
Ebay...for the overfenders...... The wheels take away that tippy feeling that I would get sometimes also
Old Dec 16, 2006 | 06:54 PM
  #18
TheBigGrizzMan22's Avatar
i have no problems with my stock 07 lights,
Old Dec 20, 2006 | 01:26 AM
  #19
willieb76's Avatar
it's hard to remember a lie but it's easy to remember the truth
Old Dec 20, 2006 | 01:32 AM
  #20
squeege's Avatar
You prolly have the new grizz 700 then cause it got 35% bigger lights this year
