Help with 1993 big bear trans oil!
Old Dec 17, 2006 | 08:54 PM
bossman0924's Avatar
Default Help with 1993 big bear trans oil!
Hello i was wondering if someone would know about the center transmission.The machine has been sitting for 4 years.I drianed the engine oil and i was filled with gas.I changed it and when i went to change the center oil(gear i believe)it smelled of gas too.When i started the motor the center oils seemed to be pushing out.Is this normal?The rear end oil was perfect.PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!Thanks
Old Dec 17, 2006 | 09:46 PM
Is there a seal that goes inbetween the 2 cases?The motor runs great i just didnt know if both the cases were one!Thanks
Old Dec 17, 2006 | 11:01 PM
recon99's Avatar
I'm not really sure what you mean, but I never really looked that close at a big bear. I thought the engine oil was shared with the transmission. Is there 2 dipsticks on it or something that would suggest otherwise?
Old Dec 17, 2006 | 11:09 PM
I beleive your right!The motor has a dipstick and there is a small allen bolt on the top which looks to be were the shaft comes out of the motor.When i pulled that the oil came out like it was overflowing.Im very new with this machine so thanks for the help!
Old Dec 17, 2006 | 11:12 PM
recon99's Avatar
Sounds like everything's ok then. Good luck and have fun!
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
