2001 Wolverine starting problems
Old Dec 24, 2006 | 05:58 PM
MNYamaRider's Avatar
Default 2001 Wolverine starting problems
My electric start isn't working right, there is a clicking that comes from the starter relay when the start pushbutton is pressed.
If I bypass the relay with heavy guage wire it starts fine.
I disconnected the incoming hot lead and the output to the started and tried it and it energizes fine, without the on/off clicking.
Is there some reason it won't work with the power trying to flow through it from the battery (new and properly charged) to the starter?
I also cleaned all the connections with no improvement.
Old Dec 25, 2006 | 12:17 AM
recon99's Avatar
I don't know what to blame that on other than the solenoid itself. The contacts inside it might be pitted, dirty, or worn out. That's all I can think of.
Old Dec 27, 2006 | 11:51 AM
GlennJ's Avatar
I agree. If the starter works fine when you bypass the soleniod...it's probably the solenoid.
njrider64
Jul 4, 2017 01:40 AM
suzuki230
Jul 8, 2016 10:03 AM
Big600twin
14
Jun 16, 2015 09:30 AM
Jbird4681
Jun 9, 2015 01:59 AM
1000gade
May 27, 2015 12:37 PM
