01 warrior NEED HELP
Old Dec 25, 2006 | 03:29 PM
01lexis300's Avatar
Default 01 warrior NEED HELP
I HAVE A 01 WARRIOR THAT I HAVE REPLACED THE CDI SATOR REGULATOR COIL AND PLUG BUT I CANNOT GET IT TO FIRE WHAT IS GOING ON HERE THE ONLY THING TAHT I CAN THINK OF ARE THE TWO RELAYS IF ANY ONE CAN HELP PLEASE DO
Old Dec 25, 2006 | 03:32 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
check all your hookups.. make sure they are all tight connections and in the right places... also.. please don't use all caps
Old Dec 25, 2006 | 03:42 PM
01lexis300's Avatar
checked everything all thight
Old Dec 25, 2006 | 03:49 PM
Speedy2222's Avatar
are you getting spark?
Old Dec 25, 2006 | 03:50 PM
01lexis300's Avatar
no spark at all
Old Dec 25, 2006 | 03:53 PM
Speedy2222's Avatar
hhmm y did u replace all the electrical in the first palce.. i am just curious
Old Dec 25, 2006 | 03:55 PM
01lexis300's Avatar
will it started when my bat exploded but it would jump start few times and i just figured no spark something electrical
Old Dec 25, 2006 | 03:58 PM
Speedy2222's Avatar
i'd see if there is power getting to the coil
Old Dec 25, 2006 | 04:00 PM
recon99's Avatar
If all the electrical components are good, that only would leave the wiring in between. Get a wiring diagram and a multimeter, and start checking for continuity and shorts in the harness. The most common location for wiring damage seems to be at the rear, where the harness rubs against the subframe. The harness flexes there, and also usually rubs against the frame and wears through the insulation or breaks wires.
Old Dec 25, 2006 | 04:02 PM
01lexis300's Avatar
would the relays have anyt thing to do with it
