350 warrior smokes and bogs
Old Jan 1, 2007 | 09:32 PM
jerber79's Avatar
Default 350 warrior smokes and bogs
just repace the coil starter relay and pick up coil because i lost spark last part to buy was pickop coil every thing ran right till i change them parts now when i start it fires right up and idles when i give it the gas it revs up and smokes blue dosent smoke while ildle just when i floor it and it boogs out to can any one help
Old Jan 1, 2007 | 10:48 PM
recon99's Avatar
Blue smoke means you have oil burning, either the valve seals or piston rings. That's nothing related to the electronic stuff, so I think the problem was there before and you never noticed it. How long was it sitting, not running, before you got it going again?
Old Jan 1, 2007 | 11:00 PM
jerber79's Avatar
ILL CHANGE BOTH TO BE SAFE THANKS FO THE INPUT HOP U COULD READ MY TYPING NOT GOOD FOR PUCTUATION WHAT ABOUT IT BOGGIN WHEN I GIVE IT GAS SLOW IT WILL REV ALL THE WAY FAST IT WILL ABOUT DIE OUT GOING DOWN THE ROAD SPITS AND SPUDERS LIKE ITS MISSIN WAS SITTIN ABOUT 3 WEEKS
Old Jan 1, 2007 | 11:08 PM
recon99's Avatar
Sounds like a carb problem with the sputtering. I'd start by taking it apart and cleaning it out good, and make sure the return spring for the accelerator pump is in place and intact. The accelerator pump is responsible for giving an extra squirt of fuel when you hit the gas quick.
Old Jan 1, 2007 | 11:14 PM
jerber79's Avatar
ILL CHECK THE CARB TO IT SAT FOR 3 WEEKS
Old Jan 2, 2007 | 06:16 PM
lucasislight's Avatar
sitting for 3 weeks shouldnt make all this go wrong...
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
