loose axle nuts
Old Jan 7, 2007 | 08:51 PM
lucasislight's Avatar
Default loose axle nuts
ok...so does anyone know if the raptor nut with the set screw will even fit a warrior??? just for my curiosity...
Old Jan 8, 2007 | 01:06 AM
fastblaster00's Avatar
if u mean the nut idk. i no the extra i had for my blaster fit my raptor
Old Jan 8, 2007 | 03:43 AM
2FAST4URASS's Avatar
Yes just get the Raptor-350 axle nut they have two set screws..so im sure ud be good to go with them
Old Jan 10, 2007 | 10:11 AM
UBETRUN's Avatar
If you are having trouble with the stock hubs on an aftermarket axle, nothing will fix your problem except aftermarket rear hubs. The stock hubs will not stay tight on an aftermarket axle no matter how much loctite or torque you apply, aftermarket axles are harder and actually eat the stock hub material. Durablue makes a very nice set of inexpensive rear hubs with a steel insert, they will not wear out like aluminum hubs and they do stay tight.
Personally, I would not put any setscrews on any axle threads that weren't designed for setscrews, you will booger up the threads and possibly ruin the axle.
Old Jan 10, 2007 | 02:30 PM
  #15
my axle/hub are both stock, yeah i decided against the nut with the set screw for that exact reason, it seems to be staying tight with just blue locktite and a pipe wrench/ pipe combination. thanks for the info on the durablue when i bend this axle ill keep it in mind!
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
