wolverine brakes
Old Jan 9, 2007 | 02:53 PM
xjjeeperman's Avatar
Default wolverine brakes
i replaced the rear brake pads on my 95 wolverine and now i have a pin hole in the rubber piece that the adjuster screw goes through. any ideas oh how to fix this or am i gonna have to replace the whole assembly cause i can't find that piece on any website. thanks *****
Old Jan 9, 2007 | 04:29 PM
recon99's Avatar
Just the rubber dust boot? Some kind of glue or epoxy would seal that up.
Old Jan 9, 2007 | 06:03 PM
i tried that but it is still coming out. and i can't get pressure on theline
Old Jan 9, 2007 | 07:48 PM
ATV_MAN's Avatar
That rubber boot should not stop you from getting brake pressure. You have air in your line.
Old Jan 10, 2007 | 08:39 AM
recon99's Avatar
Can you get a picture of what you're talking about. If you're talking about what i'm thinking of, there shouldn't be any pressure in there to begin with, which would mean you have a bad seal somewhere else.
If you're positive this is something that is supposed to be holding brake pressure, then there's not much of a chance any kind of glue is going to hold it for you, so you might as well save yourself the trouble and replace it.
Old Jan 10, 2007 | 06:45 PM
thanks for the suggestion. broke the caliper apart and its the rear seal that is bad causeing the brake fluid to leak into the rubber peice i mentioned earlier. i've got a new seal set order hopefully theyll be in before the snow hits so i can have some fun
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
