raptor 350 owners
Old Jan 10, 2007 | 11:23 PM
mm's Avatar
mm
Default raptor 350 owners
I need to know what Mikuni jets worked for you. Pilot, Main, Clip, Screw....Settings?
Old Jan 11, 2007 | 01:34 AM
rruser's Avatar
Are you looking to re-jet after installing the HMF pipe? Remember that cold weather will throw off the jetting. So if you got a main jet with the pipe, it might be too lean in the dead of winter. Lots of people run HMF pipes on warriors, i'm sure someone will be able to give you some starting numbers for jetting.
Old Jan 11, 2007 | 02:39 AM
mm's Avatar
mm
Yeah, I got the HMF. Also got a couple pilots and mains. One guy on the forum said he ran a 25 pilot and a 155 main, but he had a modified airbox. I don't. I'm pretty sure the 25 pilot will be ok, but I'm still a little iffy on the main. I guess 155 is a good place to start.
Old Jan 11, 2007 | 05:26 PM
lucasislight's Avatar
155 probably too rich for just a pipe/air filter, start with a 150 and chop a few plugs
Old Jan 11, 2007 | 07:11 PM
mm's Avatar
mm
Thanks. I will do that.
Old Jan 11, 2007 | 08:42 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
with stock filter and quiet core.. all you should need is 150 in winter and 147.5 in summer
95wolv
Sep 27, 2024 12:00 PM
bmxatv10
Oct 14, 2022 06:23 PM
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
black_thunder
Sep 22, 2015 07:59 PM
