Dash Light problem on Kodiak 450
Old Jan 13, 2007 | 09:39 AM
wilsonkodiak32's Avatar
Default Dash Light problem on Kodiak 450
All, love the forums. You guys have saved me many times in the past. Have a new problem for you. Bike is a Kodiak 450 2005 model. When I turn the key on, the dash will light up, (only the back light), the speedodmeter, hours, temp light, 4wd indicator, and gear selector lights will not show up. Any ideas?
Old Jan 13, 2007 | 11:00 AM
squeege's Avatar
You may need to replace the cluster. I would start by taking the front rack off. Take the front plastic over the radiator off....(you need to squeeze the bottom of the plastic screw thingy and turn the plastic screws at the same time) next pry the front of the radiator cover by pushing from the front toward the rear of the radiator. Once the tabs are clear, you should be able to lift up and gain access to the Pods wires. Pull the pod wires enough to locate and loosen the connectors(these 3 connectors prolly have a latch of some sort). Now you should buy both electrical cleaner and dielectric grease. ?Clean them and re-install
Go over all the connectors you can get to with that stuff to protect them from water and corrosion...
bzdok1234
30
Feb 23, 2016 01:55 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
