banshee proplems
Old Jan 13, 2007 | 09:28 PM
beaty's Avatar
Default banshee proplems
i cleaned my carbs and removed tors and now it wont idle and theres oil and white smoke coming out the pipe and when it runs its real weak and runs like crap. im lost eny one no how to fix it?
Old Jan 13, 2007 | 09:30 PM
JLsparky7's Avatar
Mods? Year?
Did you remember to cut the eletrical wire comming off your throttle when you removed the tors?
Whats your idle set like?
Whats your idle jet set like? Should be about 2 turns out
Have you inspected your reeds?
Old Jan 13, 2007 | 10:16 PM
rruser's Avatar
Did you happen to put the slides in the wrong carbs? If you put the slide from the left carb in the right carb (or the other way around), the key will be backwords and allow you to put it in facing the wrong way. The cut away on the bottom of the slide should face towards the BACK of the motor.
Old Jan 13, 2007 | 10:41 PM
beaty's Avatar
when we changed it we didnt mark the slides or enythink and we couldnt figure out witch side they went in but witch slide goes in the left and witch one goes in the right??
Old Jan 13, 2007 | 10:56 PM
rruser's Avatar
There is a wedge type pice cut out from the bottom of each slide. That edge should go towards the back of the motor. So if you look into the larger side of the carb you should be able to see the bottom of the slide cut out.
Old Jan 14, 2007 | 01:06 PM
beaty's Avatar
hey man thanks for the help it worked we ve been trying to figure that out for a couple weeks..........hey do you no enything about toomeys i was wondering if there was a diffrence in performance between t5 and t6
Old Jan 14, 2007 | 01:16 PM
JLsparky7's Avatar
The T6's are better if you plan on going all out with the motor, such as boring it and slapping bigger carbs on.
If your going to stay with the typical pipe, reed, head, timming mods then go with the T5's.
Old Jan 14, 2007 | 01:30 PM
beaty's Avatar
im planing on keeping it stock besides the reeds i got right now
Old Jan 14, 2007 | 05:17 PM
JLsparky7's Avatar
T5's would be your better choice then.
Old Jan 14, 2007 | 07:38 PM
fasterthanyou22's Avatar
I heard either way the t6's make more power than the t5s. Stock motor and carbs.
