Raptor Bogging HELP!!!
Old Dec 15, 2000 | 01:30 PM
xtreme165's Avatar
Take your P-brake off along with all that other garbage on the stock perch, I put a CR perch and lever on mine it looks better and the pull is even easier.
Old Dec 15, 2000 | 01:31 PM
ERICsRAPTOR's Avatar
You the man, 'cause I do remember when pulling in the clutch the atv would rev out. I bet that's it because it was always the same amount of bog and I do believe that the RPM range that pbrake'e limiter is just past 1/4 throttle , however as stated in previous posts I am still gonna check out the carbs bowl(have to get into it anyways).
Old Dec 15, 2000 | 02:03 PM
I could understand to wd40 in the cables but why in the parking brake area wouldn't that keep the sensor or whatever moist?
Old Dec 15, 2000 | 04:55 PM
lucey's Avatar
If you don't want to use WD 40, just use some kind of electrical contact cleaner, or wire dry. I have used WD40 on many occasions to remove moisture from spark plug caps as well as these pesky little switches. I would try whatever you have. You can remove the switches and replace the perch with the CR, but i have heard many different ways to disconnect the switch, so i would be sure you know which is the right way. I have heard to just disconnect it, and i have heard to link the the two contacts together. I would hate to damage some electrical component, so ask around if you are unsure !
Old Dec 19, 2000 | 02:02 AM
  #15
Maxmax's Avatar
When the parking break is engaged the RPM's are limited to 2,300... I also had the same problem on my Warrior. What i do now after washing the bike is to start the motor and let it idle for a few minutes so it gets nicely warmed up. That normally evaporated any water that has collected on the bike.
Black and White Raptor
Old Dec 19, 2000 | 02:03 PM
  #16
Problem solved. Can't tell you where the real problem was seeing how I took the carbs off, maintained the air filter and sprayed WD-40 into the P. Brake area. I don't know but the BEAST IS BACK.
Punch,lean,pop,hold
bmxatv10
Oct 14, 2022 06:23 PM
Sassinm1
Sep 30, 2015 04:23 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
