02 Raptor...wont start!!
Old Feb 7, 2007 | 05:21 PM
finny6944's Avatar
Default 02 Raptor...wont start!!
Well maybe it was to cold to ride after all. I warmed my quad up for about 5 minutes. It started with no problem at all even though its 12 degrees out here. I jumped on and started off, after about a mile out the quad stalled. It would not start. I dont know a whole lot about my quad yet but I checked everything I thought of. When I try to start it sounds like it wants to start but will not. I checked the fuel and it was full. Then I checked the fuel switch and I noticed that the lever was moved into the reserve tank..UNREAL...I have no idea how that happened but I was indeed running off the reserve tank. I switched it back but still , it will not start. Does anyone have any ideas? Thanks alot.
Dan
Old Feb 7, 2007 | 05:39 PM
lucasislight's Avatar
the reserve takes gas from the same tank, just from a lower spot in the tank. when you say you checked everything you thought of, what exactally did you check? did you pull the fuel line off the carb and see if it was getting gas? spark plug, etc?
Old Feb 7, 2007 | 05:49 PM
finny6944's Avatar
Oh nope...It was so damn cold out there that I had to get out of there..All i checked was the gas, fuel lever, oil, coolant.. i guess that stuff has nothing to do with it not turing over. I had to push it a long way out..Now Im warming up. Is it pretty easy to check the fuel line? And the spark plug? Thanks alot for all the help.
DAN
Old Feb 7, 2007 | 06:07 PM
turn the fuel to off. follow the fuel line from the fuel petcock (switch) to the carb and pull it off. now get a cup to catch the gas and turn the fuel to on. if it comes out of the fuel line then your carb is getting gas. i dont know where the spark plug on a rappy 660 is but its probably on the top of the motor, theres a thick ignition wire leading to a boot over it. pop off the boot and get the spark plug out with a deep well socket. the plug electrode should be tan in color. to ckeck for spark, put the plug in the boot and hold it against your frame or motor.while holding it against the frame or motor, hit the start button and see if it sparks. keep us posted, theres alot of guys here that know alot more than i do and they always are helpful!
Old Feb 7, 2007 | 07:17 PM
Hoyt34's Avatar
lol i went riding this past weekend and it was -35...my wheeler barely had a battery charge. Slowly it turned over..
Old Feb 7, 2007 | 11:51 PM
finny6944's Avatar
Hey lucasislight thanks alot. I will be heading out in the morning to see if the carb is getting gas. As far as the spark plug goes I think I have to take the gas tank off and stuff. I will look more into that but thanks alot.
Dan
Old Feb 8, 2007 | 12:34 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
If the bateery is even a little weak it wont spark. I have seen it many times.Sometimes they turn over seeminlgy fine but can still be to weak to fire it. Try jumping it from a running car or truck.
Old Feb 8, 2007 | 03:42 AM
finny6944's Avatar
Are you serious? Even though it has enough power to turn on the lights and almost start. Can I really jump my quad with my truck..Thanks alot..
Dan
Old Feb 8, 2007 | 10:45 AM
SCHOLLE's Avatar
Yes its safe to jump off. Its 12V system. Just make sure you do it correctly (same as another truck to truck).
Old Feb 9, 2007 | 11:35 PM
finny6944's Avatar
as far as jumping it goes. Do you think its neccesary because I was riding when it stalled...Doesnt that mean it cant be the battery.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
