Banshee Big Bore
Old Feb 11, 2007 | 02:07 PM
01BlackShee's Avatar
Default Banshee Big Bore
i have a 2001 Banshee with Toomey T-5 pipes and it goes great but i still want more. i was wonderig what is the best Big bore out there for it? i do trail rides and alot of straight shots. what would give me the best torque and still be reliable? Thanks in advance i ride at my cabin so there is dirt and some sand
Old Feb 11, 2007 | 02:13 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
port it.. advance the timing.. run 100LL in it..
Old Feb 11, 2007 | 03:07 PM
kfxandahemi's Avatar
Just get it ported. For trails and stuff I wouldnt get a cub or anything. You can get a good aggressive trail port and it would be enough to scare you, go that route and save a boat load of money.
Old Feb 11, 2007 | 04:20 PM
oldturtle's Avatar
This is a question that needs to be carefully researched because the Banshee has so much potential depending on your needs. You need to decide if you are willing to use race gas. Many motor mods will require that the crank be pulled out and welded and trued. So do research on different Banshee builders web sites. The best forum by far is BansheeHQ. Study previous threads and you will get more info than you can possible digest. Your T-5 is probably the best pipe for a built up motor so you have a very good start. There are many good mods that do not require a big bore including cylinder porting, head compression, carb boring/modifying, timing, etc. Just avoid throwing mods at the motor without a well thought out plan or you could wind up with an unreliable ride. Good luck. Long live the Shee.
Old Feb 11, 2007 | 08:44 PM
JLsparky7's Avatar
Get a trail port
Bigger carbs
v-force reeds
Turtle, do you like your gnarleys?
Old Feb 11, 2007 | 09:23 PM
Dunedog805's Avatar
hey go to ebay theres a guy on there in mich that does awsome porting for a fraction of the price r-b racing he did mine and it hauls
Old Feb 11, 2007 | 09:38 PM
Contact Jeff as FAST. He can get you a nasty port job and he knows his stuff...FAST Webpage
Old Feb 11, 2007 | 09:48 PM
DS2's Avatar
DS2
Good post!
Also, JLsparky...I have Gnarlys and like them.
Old Feb 11, 2007 | 10:06 PM
RDZ350's Avatar
One of my friend's has Jeff's dune/play port.Even with stock carbs,that 350 runs awesome.
I had his' drag port on alcohol.That was a very fast 350.
Old Feb 11, 2007 | 10:48 PM
Speedy2222's Avatar
talk to bobeaser on www.everything2stroke.com unbeleiveablely good at porting
