yamaha warrior cutting out
Old Feb 17, 2007 | 01:55 AM
scared's Avatar
Default yamaha warrior cutting out
I have a 2000 warrior that sat for about a year. It ran great. I recently got it running again but when you quickly open the throttle it tries to die and will die if I let it. I have rebuilt the carb but it still does the same thing. Could the air cut off valve cause this? It also puffs a little smoke at idle but cleans up at higher RPM and backfires a tiny bit on decel. It still runs and idles fine but you have to crack the throttle a little before nailing it. It only has 60 hrs on it. Any suggestions.
Old Feb 17, 2007 | 09:56 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
i'd say you are either rich or have water in your gas
Old Feb 17, 2007 | 11:46 AM
scared's Avatar
I thought water too so I drained all the gas and refilled with fresh. It is running rich but I cannot seem to correct the mixture.
Old Feb 17, 2007 | 11:53 AM
Speedy2222's Avatar
what mdos do u have and what's your jetting
Old Feb 17, 2007 | 01:43 PM
scared's Avatar
100 percent stock. Not even a K&N. I'm not sure of the jetting but it is stock too. The weird thing is it ran perfect prior to being parked. Something has happened from sitting unused. I found that the problem goes away if I crank up the idle to 2200rpm. Do you think the air cut off valve could cause this? When I pulled it apart the first time it was wet with fuel on both sides of the diaphram. However, the second time it wasn't. ???????????????
Old Feb 17, 2007 | 01:49 PM
scared's Avatar
It's almost like the choke is hanging open a little and not be sealing completely.
Old Feb 17, 2007 | 04:34 PM
rruser's Avatar
Keep trying to clean the pilot passages. The best thing you can do is totally take the carb apart again and soak it overnight. You can buy a 1gal carb dip kit at a auto parts store. Set your pilot screw to two turns out. We had a 2004 that sat for a year and it refused to run right until the carb was put in a parts washer overnight.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
