brake help please
Old Feb 23, 2007 | 09:36 AM
Raptor660JC's Avatar
Default brake help please
So I swapped brake pads on my raptor, I thought I bled the brakes right, squeezed the brakes and it feels like i'm pulling in my clutch.. am i not bleeding them right? Please help thanks!!
Old Feb 23, 2007 | 01:18 PM
2FAST4URASS's Avatar
When bleeding them did you squeez the brake lever 2 good times then hold it firmly and release the bleed valve do it 2-3 times if still a no go then do it 2-3 more time's be sure to add fluid to your rezzy!!!
Old Feb 23, 2007 | 02:26 PM
oh ok , so you squeeze the brake, release the vavle then let go of the brake? thats what i was doing wrong then! and the same applies for the back?
Old Feb 23, 2007 | 06:20 PM
recon99's Avatar
Yeah. The most important thing is that you always have the bleeder valve closed before you release the lever, or it'll suck air right back onto the line.
Old Feb 23, 2007 | 06:23 PM
lucasislight's Avatar
DO NOT RELEASE YOUR BRAKE LEVER WHILE THE VALVE IS OPEN! this will suck air into your lines and you will have to start over. this is what you need to do, whle the valve is CLOSED pump the lever a few times and HOLD while you crack the valve. you will hear air spitting out of the bleeder valve. STILL HOLDING, close the valve. repeat until only fluid comes out of the valve, and like 2FAST4URASS said, monitor your resivoir and add fluid accordingly. i think its much easier to have help doing this, but a nice tight bungee works to hold the lever. or just reach with your free hand. good luck!
Old Feb 23, 2007 | 06:47 PM
ok I just bled the brakes and it worked great...it does feel a little mushy but it just might be my imagination...thanks again for your help!
Old Feb 23, 2007 | 06:50 PM
it wouldnt hurt to ride it for a little while and then repeat the bleeding process. it may help the mushiness.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
