Grizzly 700 Shifter Adjustment ?
Old Feb 24, 2007 | 08:42 PM
ExtremeYamaha's Avatar
Default Grizzly 700 Shifter Adjustment ?
Grizzly 700 Shifter issue :
Does any one have a fix for this shifter. Is it a linkage issue ? The quad is hands down the best thing I have ridden, however, the shifter is driving me crazy. No matter how low the idle, or if I do the "Take the machine out of park tango " you feel like you are going to break off the lever.
Old Feb 24, 2007 | 08:45 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
sounds like it needs loosened.. so it has more play.. how u do that.. i am not sure but that is what it sounds like to me.. does this only happen at certaintimes.. or is it an.. everytime anywhere kind of things?
Old Feb 24, 2007 | 09:32 PM
VTX1800's Avatar
I just picked up my 07 Grizzly today. The shifter was one of the first things that I noticed. I hope someone has some suggestions to make it a bit easier to use.
Old Feb 25, 2007 | 02:14 AM
captainskodiak's Avatar
i agree the shifting can be a bit difficult at times. It seems like it is the worst going from drive to nuetral. I went from high to reverse then to nuetral to get it into nuetral sometimes. I will check with my dealer to see if there is any adjustment. BTW I put about 30 miles on the new Grizz today, and it performed very well. Of course I took it very easy for the break in, but still it has a ton of power at half throttle. Not real happy with the stock tires, I already have someone that wants them, so I will soon be changing to my Mudlites and ITP wheels. Other than that I really like the new Grizz.
Old Feb 25, 2007 | 11:46 AM
VTX1800's Avatar
I asked my dealer about it. They said it helps to have your foot on the rear brake and sometimes you have to rock the bike back and forth. I tried that and it did help some.
Old Feb 25, 2007 | 01:18 PM
2TV's Avatar
2TV
BTW in case the new Grizz owners weren't aware, you must engage the back brake in order to shift in / out of Park or Reverse. There is an interlock switch that is controlled by the back brake.
My '02 Grizzly used to shift a little hard too, but it has gotten buttery smooth with age. The 700 seems to be a little stiffer though. Sometimes I can not go straight from Park to Low. When that happens I stop at neutral, blip the throttle, let it go back to idle then shift it the rest of the way. I haven't looked into a solution yet because it doesn't do it that often...
Old Feb 25, 2007 | 02:03 PM
JDGrizz's Avatar
Yep, what 2TV said. My 07 Grizz 660 has a rear brake interlock for park and neutral. Either the rear brake foot pedal or hand lever must be depressed to shift. The shift linkage was a little stiff when new but is smoothing up with use. I have also read on other boards of some 700 bikes needing the shift linkage adjusted slightly.
Old Feb 25, 2007 | 02:05 PM
GrizzlyJim's Avatar
My shifter in stiff too, mostly going from high to neutral.
Old Feb 25, 2007 | 03:29 PM
I am well aware that you have to use the back break to shift, I even use both brakes at times. As I stated earlier, the "Take me out of park Tango" meaning hold brakes, rock back and forth. I just don't think that it's good for the shifting mechanism to be that harsh. There has to be an adjustment or somehow to make it smoother.
Old Feb 26, 2007 | 12:49 AM
MALAHATMAGUIVER's Avatar
The shifter gets much better after you log some hours.I agree that the shifter is a pain.I removed the shift lock cable from the machine....It takes about a half hour to remove and it can be reinstalled with ease.It was such a treat to not have it compounding the shifter ignorance.
Give it some time.
Pgbama11
Sep 10, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
