blaster question
Old Mar 4, 2007 | 06:42 AM
JLsparky7's Avatar
Default blaster question
Originally posted by: recon99
$400
and how can it be in "mint" condition if it's all cracked up and doesn't run right? lol
+1, I agree.
Old Apr 1, 2007 | 10:03 PM
rjones's Avatar
my blaster is having clutch problems i had bought brand new clucth kit and a mouoth latter its slipping what can i do to fix this
Old Apr 1, 2007 | 10:09 PM
recon99's Avatar
what kind of clutch? what kind of gear oil are you running?
Old Apr 1, 2007 | 10:14 PM
rjones's Avatar
i used 10w 30 oil barrnet my freind said that that kit was the best for my blaster
Old Apr 1, 2007 | 10:19 PM
  #15
recon99's Avatar
10w30? like just regular 10w30 motor oil like you put in a car?
Old Apr 1, 2007 | 10:21 PM
  #16
rjones's Avatar
yea its said to be put in 10w30 oil for 30 mins
Old Apr 1, 2007 | 10:27 PM
  #17
pabst660r's Avatar
i would say its worth in between 500 and 750 bucks.
  #18
recon99's Avatar
You shouldn't be using regular automotive oil in anything with a wet clutch. Modern automotive oils have all kinds of friction modifiers and moly, which is designed to make everything as slippery as a greased fat kid on a wet marble floor, and the moly is designed to fill in any kind of pits or imperfections in a surface, so it fills in the surface of the friction pads so they don't grab anymore. Sorry to say it, but your new clutch may be fubared.
Old Apr 1, 2007 | 11:25 PM
  #19
rjones's Avatar
how come it worked for a month
Old Apr 2, 2007 | 01:43 AM
  #20
recon99's Avatar
When a clutch is new, and not broken in, naturally it's going to have more friction because the surfaces haven't been worn down at all. Between the combination of the pads smoothing out from normal use, and all the friction modifiers filling it in and soaking into it, that's pretty good reason for it to be slipping. The only other thing I can tell you is obviously make sure your cable is adjusted right. Other than that, you'll just have to tear it apart and see how it looks, or you can try running some of the right oil through it and see if it flushes the bad stuff out. That might get it working again, although it'll probably never perform as well as it should.
