questions on warrior
Old Mar 7, 2007 | 12:27 AM
warrioryamaha94's Avatar
Default questions on warrior
and on the on/off switch....tonight i sanded down the handlebars where it would ground, i moved some ground wires around to see if it would do anything and nothing...i could use some ideas on that too i thought maybe it was grounded cause the start button works but i pulled it off the handlebars and the start button works no matter what so im out of ideas
Old Mar 7, 2007 | 12:33 AM
recon99's Avatar
The splines match. I wouldn't have told you they work, and made the statement "all the splines match" unless I meant it [img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 7, 2007 | 12:43 AM
ok well thats good news i was just making sure im hoping its just bend it/take an inch out or so and go
Old Mar 7, 2007 | 12:47 AM
recon99's Avatar
you say "the start button works". How do you know this?
Old Mar 7, 2007 | 12:49 AM
  #15
the start button works it starts and runs and everything it just wont shut off by using the run switch i took the whole peice off the handlebars and pushed it and it still started up
Old Mar 7, 2007 | 12:53 AM
  #16
recon99's Avatar
ah nevermind, i was thinking of another thread where it wasn't starting. What I would do is just try to figure out the wiring schematics and trace the wires.
Old Mar 7, 2007 | 11:43 AM
  #17
54warrior's Avatar
I always leave mine on "Run" and use the key to turn it on/off. Have never in 10 yrs of riding needed to use the switch on the bars, and if I did, I was too damn slow at hitting it anyway!!!
Old Mar 17, 2007 | 09:02 PM
  #18
54warrior's Avatar
I just remembered about this thread and after just glancing through some old pics, I noticed this one of my shifter, so I scanned it in.
54warrior's Shifter Mod
Old Apr 1, 2007 | 07:01 AM
  #19
giddle's Avatar
pop the linkage out of the shifter and just run a bolt wit a washer in it and it will do away with the linkage
Old Apr 1, 2007 | 12:02 PM
  #20
recon99's Avatar
I really don't get what you mean with this, but sounds like that just leaves you without a shifter at all...
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
