Yamaha warrior timing chain tensioner
Old Mar 12, 2007 | 12:15 PM
finkledinkle's Avatar
Default Yamaha warrior timing chain tensioner
How do you adjust the tension on the timing chain on a 96 yamaha warrior? I started to take engine apart to rebuild and changed my mind and i think i did something to the tensioner and now it has a ticking sound in the top end. Any help would be appreciated. Thanks.
Old Mar 12, 2007 | 05:49 PM
recon99's Avatar
It's an automatic tensioner. If your chain is loose then either you messed up the tensioner or didn't re-install it correctly, or you need a new chain.
Old Mar 12, 2007 | 07:12 PM
So there is no way to reset it or anything like that? Thanks for the help.
Old Apr 1, 2007 | 07:04 AM
giddle's Avatar
no not really if your timing chain when ur holding it up goes like a rainbow its bad u also do this weld a bolt on the end of ur tensioner and that will give you some more tension the olny reason i kno wthat is when i bought mine thats how it was set up
njrider64
Jul 4, 2017 01:40 AM
mikey426
Jun 17, 2015 03:53 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
dunc_n
Aug 26, 1999 09:32 PM
