02 Raptor Reverse Light - Rev Limiter - Revised
Old Mar 13, 2007 | 03:09 PM
GregV's Avatar
Default 02 Raptor Reverse Light Blinking - Dies when in Neutral
Hey, I need some advice if you have time.
I put my engine back in and got it running again after some pretty extensive mods, but I am having a weird little issue with my Reverse Indicator light?
I can get it in Neutral and push it while it's not running, so I know that it is truly in Neutral. When I turn the key on, the Reverse light comes on and stays lit until I start it up. Then it starts blinking every 2 seconds and stays that way? Then While it's running and in Neutral, if I let out on the clutch it will immediately die?? It has to be some dumb little electrical thing that I am missing.
Also, when it's in Neutral....the Neutral light does not light up.
Any ideas??
It's on a 2002 Raptor. The Emergency Brake has been removed and has been off for 3 years or more. It seems like there is something to the E-Brake.....but I can't remember, it's been too long ago.
Old Mar 13, 2007 | 10:57 PM
GregV's Avatar
Update........
I have it Idling now with the clutch out, it isn't blinking now, but the light is still staying on. I did run it up the drive way today and when I gassed it a bit and the rev-limiter kicked just like it did when I removed my Emergency Brake. From what I remember, I had to mess with the wireing. It's been a long time since I altered it.
It looks like it a Grey/White wire on the wire diagram. I'll have to do some digging, unless someone out here is fresh off doing the job that could refreash my memory.
Thanks
skinnyr6
Aug 25, 2023 02:18 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
