700 grizzly still stalling
My 700 Grizzly is just coming up to 500 miles and it?s occasionally stalled from the day it was new, but out on a ride today it stalled at least 5 times, I?ve been reading all the threads concerning this problem these past few months but still not sure what?s causing it. The symptoms that I get are, it only happens when the engine is fully warmed up and I stop the engine for a short time any thing from 2-5 minutes and the shifter is always left in High, when it?s re-started as soon as I hit the Gas there?s a slight splutter and it stalls I re-start it immediately and it?s fine, any advice please.
You should determine if reverse light comes on concurrently with the missfire. If so then adjusting the shift linkage slightly tighter will usually solve problem. Try only about 1/2 turn tighter and then test ride. This worked for me and most others with this problem. Some have reported finding a defective reverse indicator switch.
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
