Should warrior be jetted
Old Dec 21, 2000 | 12:04 AM
Theputsman's Avatar
I just put on a white brothers pipe and added a K & N filter with air box vents to my warrior, The dealer said it was not required to jet the carb. Should I rejet the carb and if so what size main should I use. I'm at about the 3000 foot elevation . I do notice a lot more power now. What else can I do to increase power with out going into any major engine work.
Old Dec 21, 2000 | 02:09 AM
hot_shoe_cv's Avatar
Well, I sure wouldn't take any stock market tips from your dealer! Whenever you increase the air flow by adding better exhaust systems, you cause a lean fuel mix to occur. You compound this by adding a better filter and further yet by opening up the airbox. You need to run a test & plug read right away to see just how lean you are. Your stock main is a 145. I would guess that you'll need to go to at least a 150 main jet to supply the correct fuel to the mix.
As I tell any one who will listen, only YOUR engine can tell you what it needs in the way of fuel.Install a new plug, do a test ride at 3/4 to full throttle. Stop & pull the plug to check for color. grey or white is way lean. Tan or brown is correct jetting, black or dark is rich. It is unlikely that the latter two will be there.
I would definitely do this before any extensive hard riding.If you need more info on jetting or plug reading, I have written an article and a photo which I can email.
Old Dec 21, 2000 | 11:34 AM
Theputsman's Avatar
Hot Shoe
Thanks for the info. Can you e-mail me that info, My e-mail address is in my profile.
Old Dec 21, 2000 | 08:02 PM
WildTurkey's Avatar
I'd say there's 99.9% chance you'll have to re-jet. The only way you wouldn't is if your altitude falls into play. In that case, it would have been running rich since you got it.
Pull the plug, it'll tell you. Most likely you will have to go up a size or two.
Old Dec 21, 2000 | 09:36 PM
Theputsman's Avatar
Thanks Cal
I got both e-mails. That helps out alot
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
